Results 1 to 4 of 4
    Sep 2014
    Somewhere
    Default Sharan 2.0 CFFB , year 2011, adblue and dpf off needed
    Hi to all!
    Please help with adblue and dpf off on this sharan year 2011, 2.0 engine CFFB (ECU 03L906018HH).
    i also need to remove dtc from exhaust presure sensor and exhaust temp sensors, because I have errors on them.
    Thanks!
    mariusica_boy's Avatar
    Quote Originally Posted by Jashmine1983 View Post
    Hi to all!
    Thanks!
    Tested solution dpf off + adblue off.
    U can disconnect all sensors from dpf and adblue if u want.
    Pass in PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following 2 Users Say Thank You to mariusica_boy For This Useful Post:
    Jashmine1983 (5th August, 2018), masterb (25th August, 2018)
    Sep 2014
    Somewhere
    Quote Originally Posted by mariusica_boy View Post
    Pass in PM.
    i have ktag clone...will make chksum?
    Sure ktag can calculate checksum in writting
  6. The Following User Says Thank You to mariusica_boy For This Useful Post:
