Results 1 to 5 of 5
    Jan 2018
    south africa
    Default help needed chevrolet utility 1.4 cluster securiy pin
    hi I need too know which eeprom needs too be read from this cluster from a Chevrolet utility 1.4 too retrieve the security pin tried carprog op.com via obd no luck need to do a key for this vehicle help will be appreciated thanks jacques
    Jan 2018
    south africa
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Post the dump mate to be able to retriev the security pin code
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
    Jan 2018
    south africa
    thank you so much going too read it shortly with upa i believe it is m35080 eeprom ?
    daniersms's Avatar
    South Africa
    It is a 35160 serial eeprom and yes you can get the code from there and program a key with Opcom
    Love this forum
  6. The Following 2 Users Say Thank You to daniersms For This Useful Post:
    awesome88 (19th March, 2024), jacques23 (6th August, 2018)
