Results 1 to 4 of 4
Thread: Astra H DPF Off
    dunkler's Avatar
    May 2009
    Hatzfeld
    Default Astra H DPF Off
    Can someone check if DPF is disabled properly in this file?
    If not can someone do it professionally ?
    Both files attached
    Thank you
    mancioks's Avatar
    Feb 2017
    Germany
    Here u go, tested solution.
    Don't forget rep and thanks when test
  3. The Following User Says Thank You to mancioks For This Useful Post:
    dunkler (6th August, 2018)
    dunkler's Avatar
    May 2009
    Hatzfeld
    Volta? Ecusafe?
    DTC Table deleted?
    Sorry but no
    Tried to find the switch "00 00 01 00 00 00 28 44 00" but looks already disabled (00)
    Any clue?
    mancioks's Avatar
    Feb 2017
    Germany
    Only dtc deleted related to Dpf + sensors emulated that you can disconnect them. Don't want don't try but this is tested with sensors and without.
