Results 1 to 3 of 3
    Aug 2018
    Default Modus faulty steering column-swap EEPROMs
    Hello everyone,
    i have a faulty modus stering column. I am going to fit a second-hand unit from a scrapyard. Do you think it works if I swap the eproms between the faulty unit and second hand unit? So that I would not have to virginise the eprom in the second hand unit? Do you think that may work? thanks
    May 2010
    Hello,
    Yes, it will work if the structure of the dump is the same.
    Salut,
    Oui, cela fonctionnera si la structure du dump est la même.
    Sep 2015
    Probably if you virginize your steering dump the steering column is ok.
    used steering have to ne the same family of parts (trw1,trw2,..) and the same brand car.
    you Can have problem with steering comunication and steering respond.
