It should read this ecu without any problem
Hello guys.
Anyone
Read / Write ecu with sucess via Kess 5.017?
Customer get a car but he got only kess, im not shure what should i tell him.
Car is FORD MONDEO MK4 DCM3.5 2.0TDCI 115KM
DSG TUNING
File Service
but would it write it,can anyone confirm kess is OK for writing this ecu
Is ok ,i’ve made a couple of them without any issues .
ivanmihov (7th August, 2018)
i need to be 90% shure ( 10% is just ~~~~ed ecu what can happens with genuine tool also )
if anyone have troubles with it, customer just skip this car
DSG TUNING
File Service
This is simple ECU. I write it on car even with 11,2V. Never have any problems. ANY. 5.017, clone.
maajkii (7th August, 2018)
No problem ! I did it several times on Delphi DCM 3.5 PSA. Must be OK for Ford.
Jep, possible with clone
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Just The info.
Sucessfully read/ write via OBD.
Wysłane z mojego SM-G935F przy użyciu Tapatalka
DSG TUNING
File Service
jenny123 (10th August, 2018)
Why so much false info?
Many people complain about corrupting flash with Kess v2 even original! on this ecu. i tested 3 of those cars around year 2010 and kess does not read correctly! Only woth doing by bench with ktag.
