Page 29 of 63 FirstFirst ... 19242526272829303132333439 ... LastLast
Results 421 to 435 of 937
  1. #421
    Quote Originally Posted by delboy71 View Post
    Try the method at the start of this thread it will work if you follow it correctly step by step. Dont forget that black wii's do not play back up dvd's,playing games is either external hhd or large pen drive only.
    Good luck and read the tutorial "carefully" take your time.
    Already looked it and seems to be quite hard to read and understand non-englishman Long tutorial..ok im quite rookie on this.
    Am i right theres no ready package to copy/install to SD and so on ?
    Do i have to got Internet connection before i start to modding?
    Could it be cause i have SanDisk 2gb Sd-card its not work?
  2. #422
    Top Poster delboy71's Avatar
    Nov 2008
    Q. Am i right theres no ready package to copy/install to SD and so on ?
    A.all the files you need are there,but you need to put them on sd a step at a time.
    Q.Do i have to got Internet connection before i start to modding?
    A.no you dont providing you are on 4.2e already.
    Q.Could it be cause i have SanDisk 2gb Sd-card its not work?
    A.SanDisk are the best for the wii,so i have found out.
  3. #423
    I'm having trouble running a few games from disk and Im thinking about buying a large pen drive to see if that solves the problem, but I thought I ask you guys to see if you think buying a large pen drive will solved the problem cos I dont want to waste my money if not.
    Most of my games work fine, however a few won't load for whatever reason. When I load them in uloader, this is what happens.
    The title of the game shows up in the uloader menu, but when I press 'load game', that's when it all starts to go wrong.
    Sonic unleashed
    Super Monkey Ball - Step & Roll
    Wont even load banner title
    Mario & Sonic at Olympic Games
    Lego Indiana Jones 1
    Loads banner title, then says loading for about 1 minute and then freezes on a black screen.
    Ive burned all my games to TDK DVD-R using ImgBurn at 4x speed, all PAL and all my games are from sources that other people have claimed to be working fine. I'm using the latest version of uloader, because I just updated it to see if that solved the problem (think it said it was uloader 4.8)
    Shall I try burning them at a different speed?
  4. #424
    V.I.P. Member ck-ok's Avatar
    nottingham
    Quote Originally Posted by sam.walker22 View Post
    Sonic unleashed
    no need to spend money its all to do with ios's Which IOS Games Use To Run check what ios you need and google it or get http://www.digital-kaos.co.uk/forums...1-3beta-95556/ and get your own
  5. #425
    Quote Originally Posted by ck-ok View Post
    Ok thanks. I am following your instructions and I've gotten as far as this..
    start nusd and file will download to pc and then packed into a wad which will be in nusd folder,there will be a folder in there with lots of files in it all you need is wad file, put wad in wad folder of sd card and install with wad manager.
    I now have a folder in my NUSD folder called 0000000100000021v1040 with lots of files in (such as 00000001, 00000005, cetk, tmd.1040) but no wad file?
    I downloaded IOS 33 - v1040
    EDIT: Sorry, I forgot to check pack wad at the bottom!
  6. #426
    Ok, I think I know what I'm doing but I just want to clarify with you first incase I brick my wii!
    I'm using firmware 4.2e.
    I'm trying to get Sonic Unleashed to work, so I checked on the list you linked me to and found it as:
    Sonic Unleashed........................IOS33-64-v1040............System Menu 3.1
    So in NUSD, I've checked Pack > Wad
    clicked Database
    selected IOS 33
    and v1040 (or do I click latest version?)
    then clicked Start NUS Download
    Ive then put the WAD file that I've downloaded in my WAD folder on my SD card.
    Because for Sonic Unleashed, it says to use System Menu 3.1 and not 4.2, I presume that I am ignore the part of your instructions that mention using 'trucha features', right?
    Then I go into wad manager and select to use "IOS 33"?
  7. #427
    V.I.P. Member dell_xps's Avatar
    Try a different make of disc m8.
  8. #428
    Quote Originally Posted by dell_xps View Post
    Are TDK not any good?
  9. #429
    nottingham
    dont know if there any good or not,i use verbatim dvd-r,your last post iscorrect ifthey dont get you going then as dell says change your disc's
  10. #430
    I couldnt install IOS33 - v1040, but it would let me install the latest version, so I did that.
    After installing, tried loading sonic unleashed but it still can't get past the 'reading the banner..' stage in uloader.
    If I have to change my discs, would I better getting the large pen drive then? I can get a 128gb one for ?20 on ebay so not too expensive.
    EDIT: Just tried Lego Indiana Jones which, according to the IOS list, uses the same IOS that I just installed for sonic and now when I try and load it, it gets to the 'reading the banner..' stage and then shows a black screen with lots of white numbers on it saying 'Exception (DSI) occurred!' ?
  11. #431
    nottingham
    the drive is up to you,dont sound a bad deal,as for the stack dump error these happen from time to time,if it happens again and you think the iso wad is to blame just uninstall it with wad manager.
  12. #432
    I'd be sceptical of getting a 128GB pen from Ebay m8, majority are fake and only hold a percentage of space they claim to have, buy a stick from a known dealer, ie Ebuyer etc etc, or buy a few different DVDR's and see if any of them make a difference.
    Another point, are you burning these discs via a notebook writer ?, If so try using an external writer or try burning them in a tower PC if you have one, or borrow someone else's PC to eliminate your writer.
    HTH.
  13. #433
    Great all seems to have gone ok. I still have some questions.
    Which system hacks need to be enabled in peiiloader to protect the Wii (not just background and sound stuff)?
    Should I update ULoader? The highest version I can find claimes to be 4.8b.
    Also
    cIOS249-v14.wad
    cIOS250-v14.wad
    Are now
    cIOS249-v17.wad
    cIOS250-v17.wad
    You probably know that already but I thought I'd point it out.
    Thanks again for the advice.
  14. #434
    HTH.
    Yeh I have been using my laptop to burn them, I'll try using my friends pc thanks.
    I've found these verbatim dvd-r's on amazon, would they be ok?
    [ame=http://www.amazon.co.uk/Verbatim-43522-DVD-R-4-7GB-Spindle/dp/B00097CCZK/ref=sr_1_5?ie=UTF8&s=electronics&qid=1267198788&sr =8-5]Verbatim 43522 DVD-R 16x 4.7GB, 25 Pack Spindle: Amazon.co.uk: Electronics & Photo[/ame]
  15. #435
    nottingham
    have you got a pound stretcher/instore shop near you same disc's are ?5
