Wii 4.2E softmod tutorial. Easy to follow guide. - Page 3
Page 3 of 63 FirstFirst 123456781353 ... LastLast
Results 31 to 45 of 937
  1. #31
    V.I.P. Member dell_xps's Avatar
    Folllow the tutorial carefully m8, and you'll be ok.
    HTH
  2. #32
    Sweet, it worked now running uloader and it's awesome. Thanks for the help.
  3. #33
    Quote Originally Posted by bobmarsh View Post
    Nae probs m8, were here to help !!!
  4. #34
    Wicklow
    Default works great
    hi, just installed this, was on v4.o and updated to v4.2. ran all the files and not a bother, great stuff.
    i had the previous v4 soft mod previously, but still have the dvd back up launcher, cant seem to get rid of this channel, any ideas what to do. thanks again
  5. #35
    Quote Originally Posted by wabbit View Post
    Cant you go into the Wii settings m8 and just delete the channel ?
  6. #36
    Wicklow
    yes , just went in and deleted it, it wasnt named properly, was called ??? on channel list.
    dont know if i should start a new thread, but cant get fi.fa 2.010 to work, just stays on loading, just locks,??
  7. #37
    002 fix on when trying it m8?
  8. #38
    Many thanks, dell_xps. Being new to this, I was rather intimidated by the process... But with your info and links, it turned out to be relatively painless. Cheers!
  9. #39
    Quote Originally Posted by thoracic View Post
    No probs, here to help m8, enjoy the forum.
    Tell yer friends about this excellent forum to.
    Digital Kaos Numero Uno.
  10. #40
    Nov 2008
    If i used this guide could i update my wii from 3.2 to 4.2??
  11. #41
    Quote Originally Posted by perkinini View Post
    better staying at 3.2 m8.
    HTH
    Use Zelda if you have it to softmod, or V1 of bannerbomb.
  12. #42
    May 2008
    Default Softmod problem
    I softmodded my wii (version 4.2E) using the guide from wiihacks, when loading a backup the disc just said wii update, I seleted this and got a message saying system files corrupt. The wii still boots ok and I can play most backups (it's also hardmodded), but whenever I try to load a game from the usb hdd I get a stack dump.
    After installing the homebrew channel for the first time I installed bootmi as boot2 and took a NAND backup.
    Would it be wise to restore the NAND backup and start again ?
    Cheers
    Chunkey
  13. #43
    Omg! Thank you so much Got everything working a few days ago, looked hard but was verrry easy
    Just 1 question, how do I install homebrew programs on to the channels page like uLoader? I'd love to put MPlayer as a proper channel. Thanks
  14. #44
    Default wii 4.2
    i can get some of my wii games back running on a wii 4.2 from main boot screen by useing Wad Manager 1.4 to laod all the wad files from corpv3.5M like cIOS09-v5149-v3.5.wad and so on still need to find away to get the ones that wos using NeoGamma before
  15. #45
    Quote Originally Posted by dell_xps View Post
    It's been a while since I did anything with the Wii, anyways I was asked to softmod a 4.2E, tried a few tutorials but couldn't find anything quick and easy to get it done. ( I know there's a few tutorials posted but i couldn't get anything to work with the 4.2E firmware). After a few hours of searching/googling I came across this well written tutorial, only thing I changed was the Neogamma Loader to play back ups with the 002 error, everything works great now.I take no credit for any of these tutorials, I'm only pointing people in the right direction as I thought It was a pain in the (*)(*) to find out how to softmod a 4.2E Wii.Anyways.............
    Here goes, this should take you no more than 30mins tops, I have only done this on a 4.2E version.....
    Download bannerbomb v2 from here,
    bannerbomb
    follow the instructions, as soon as you have the homebrew channel on your Wii your good to go......
    Next.....
    Visit this website,
    HOWTO: Setup a System Menu 4.2 Wii for playing backups of commercial games with uLoader Ade's Softmodding Wii blog
    Download the file complete4_2.zip, and follow the tutorial.
    As I said earlier I used the Neogamma loader to get games with the 002 fix error to work, all other games play no problem via the USB loader.
    There's probably a newer bit of software out there, I'll amend my post later if there's a better solution, but for now this will get you up and running without the need to look around for hours and hours.
    This may work on earlier firmwares also.
    Uploaded the neogamma loader,just put this on your SD card in an Apps folder.
    My friend i would just like to thanks you for all you have done it worked perfectly if you live anywhere near manchester ill buy you a beer am that greatfull thanks very much XD
