Why is Uloader giving the message: "ERROR: Can't Mount Device"? . The way around it is to disconnect and reconnect the usb stick and then it works, but I have to do it everytime, is it normal?
Thanks for your support
Hi there,
I just got a black Wii for my son for his b-day. It is on 4.2E. I read a lot about softmodding the Wii, but there are still unclear things about it. Can I softmod the 4.2E and play burned discs? I heard & read, that the black ones can only be modded to play the ISO from external USB or HDD drives. I would prefer both solution at once, but don't know if that is possible.
BrickBlocker: should I run the downloaded ISOs, independent from PAL/NTSC versions, through it? I already D/L-ed some PAL games, but I fear they might update the device to 4.3.
Thanks for answering the questions of a newbie.
install priiloader to block disc updates and online updates this tut will show you how http://www.digital-kaos.co.uk/forums...loader-109168/
Any ideas on how and where to get this? I have a Wii which is upgraded to version 4.3E and my Softmode is for 4.2 and do not work on this Wii version 4.3E???
I can't use the link? Any new ways to get hold of this? I've been told that it can fix a Wii 4.3E? Or should I try any new Softmodes?
What would be the best way to mod a console that is currently on 3.3, use the safe 4.2 updater and then run this one??
Many thanks for any help
Guys,
This is my first time attempting this. I installed the homebrew & bootmii through bannerbomb no probs.(My system 4.2E) I have copied pack to sd card and launched in homebrew channel. I think I may have made an error by using yet another wad manager & deleting the wads from the sd card rather than wad manager. So I reloaded the card with the pack and started again, this time using the correct wad manager but none of the files were found, in MMM i try to install the necessary wads but this doesn't work I get an error. Any help would be greatly appreciated. Cheers
To explain a little better than my last post-
I got to section 7) Without any problems, but did not find the mentioned wads 222,223 any of them.
Did 7.1 any title deleter nothing in system titles and couldn't find a folder named 'other system files' so checked all menu items abd nothing there either.
Section 8 I accidently went to yet another wad manager, and deleted the files I was looking for from teh SD card i.e 222,223 etc.
Does anyone have any idea what went wrong & how I rectify this?
Cheers
