Page 60 of 63 FirstFirst ... 1050555657585960616263 LastLast
Results 886 to 900 of 937
  1. #886
    V.I.P. Member ck-ok's Avatar
    nottingham
    Quote Originally Posted by downsy View Post
    Hi All, new to the site but from what i have read you guys know what your talking about.
    I have a wii that was previously modded but stupidly it has been updated to 4.3e.
    I have downloaded a couple of files but with no joy, i read a post that said I could upgrade mod without using indy method due to already having a previous mod.
    I only have homebrew channel on the system now as a earlier post i tried told me to delete all backup loaders etc.
    So guys can I mod my 4.3e in this state and whats the easiest way.
    Not sure if im putting things onto sd incorrectly but when i try to use progs through homebrew the wii remote shuts down and i have no control and end up restarting.
    Hopefully somebody can help
    Thnks in advance
    Downsy
    read here http://www.digital-kaos.co.uk/forums...-3-mod-157379/ iv'e updated the tut to cover your problem
  2. #887
    Dec 2010
    Ok. I bought the lego Harry Potter game for my brother. It needed an update. I updated it using the wii but as far as I know it didn't have an internet connection. The game worked.
    I also have a copied version of Mario Galaxy 2 which I was previously using on Neogamma. Now that doesn't work, and when I try to install updates using a WAD manager the wii remote stops working and won't respond.
    I am currently lost as to how to fix this...
  3. #888
    Dec 2010
    Ok I have a very similar problem to Downsy. Except mine's on 4.2E
    Do I have to re-install the homebrew channel?
    The only real problem I have is the wii remote freezing when in the WAD manager because then I can install IOS's to fix the problem...
  4. #889
    Dec 2010
    Hey CK -OK thanks for reply, sorry a bit green with all this, the link to tut you gave , do i just download mmm61 file and continue tut from "now you can install hbc and bootmii" or do i need to do the indy game thing ? sorry to be a pain getting confused very easy . As mentioned above HBC is on my 4.3 system currently.
    Thanks again
    Downsy
  5. #890
    Dec 2010
    http://www.digital-kaos.co.uk/forums...manager-75307/
    Post #3 in here
    I tried it and it worked
    but i tried it again later and now I cant turn on my wii unless the SD card is in and then it only goes to the wad manager or the cios installer.
    PLEASE HELP I AM FREAKING OUT HERE
  6. #891
    Dec 2010
    Ok disregard that, I accidentally uninstalled the wii menu... PHEW
  7. #892
    Jan 2011
    Nice tutorial, this will be the the first time im going to do this. I have firmware 3.3e, so ill update to 4.2e with v4.2 safe firmware updater. and use bannerbomb guide to install homebrew. Then ill start the tutorial, hope itt will work!
  8. #893
    Dec 2010
    hi used ade older version before and i need to redo a new one please which one should i use please to soft mod 4.2e
    my son bricked the older one by accident
  9. #894
    nottingham
    Quote Originally Posted by enilorac View Post
    if you want a tutorial that upto date use this http://www.digital-kaos.co.uk/forums...indows-170234/
    as for your old one being bricked what happend to it?
  10. #895
    Dec 2010
    got help from you last week as i was trying to get glee working he went into something and all i had left on the wii was the boot2 ? there was nothing else i tried to run a back up with the nand spent a few hours trying so had to go away and buy a second hand one before my husband found out i couldnt be listening to him give out because it was both our fault
    what exactly do i do with all the files please
    i will format my old card
    do i put the file straight onto the root or must i open it
    put into the wii press sd card and should it be ok from there
    caroline
  11. #896
    nottingham
    put into the wii press sd card and should it be ok from there,and have you tried following this http://www.digital-kaos.co.uk/forums...loader-109168/ tut for your old wii?
    caroline
    you can use this tut or use the modmii, if you use modmii its a pc program.it will ask you a few questions then put the files on the sd card for you and write you a tut aswell
  12. #897
    Dec 2010
    wow this thing is amazing
    never seen anything like it now thats not saying a lot but thank so far so good
  13. #898
    Jan 2011
    Wii version: 4.2e
    I have installed HomeBrew Channel, trying to enable/add USB loader. I am trying to follow the instructions. In step 9 when trying to load WAD I am getting error! (ret=-2011). not sure how to fix this, however,I used the ("Another WAD manager") it loaded all the 8 wad files.
    The uloader channel is appearing. I formatted a usb drive(512mb) with WBFS manager and installed in one of the USBs at the back. When I launch uloader, I am getting an error message something like "no device available..".
    Thanks for your help.
  14. #899
    nottingham
    Quote Originally Posted by ksbhasker View Post
    Wii version: 4.2e
    it needs to be in bottom port if its lying down
  15. #900
    Member tripper's Avatar
    Jan 2011
    collingwood victoria australia
    can this be used for 4.3 e as well or not can you please help thanks again
