Results 1 to 5 of 5
    Sep 2010
    Default VW passat cc 2.0 tdi CR dpf and adblue off but smoking
    Hello.
    I'm trying to help a friend how is a mechanic. He has a passat cc, to work on, that has dpf and adblue off but smoks alot. Pls forum users help me find out if it's done correctly. I have no experience with this type of ecu.
    Here are the specs -> ECU: edc17 cp20, SW: 1037508388, SW upg.: 03L906022DJ 7374.
    The read was done in boot mode with fgtech galletto 4.
    Sep 2010
    Hello. No one who can help me, pls?
    unnamed11112007's Avatar
    Aug 2015
    Belarus Molodechno
    try this mod file and report
    ------------>WinOLS_ (MOD_DPF OFF)_508388_NO CS_(DizelDiag).rar
    pass pm
    tell me thanks I will be very happy
  4. The Following User Says Thank You to unnamed11112007 For This Useful Post:
    h0m3s1ck (9th August, 2018)
    Sep 2010
    Hello @unnamed11112007, thank you. Unfortunately fgtech galletto 4 says that can't calculate checksum. Pls help me with cks corection to. From the name of the file it is dpf off, can you also do the adblue off, pls?
    I hope you don't consider me beeing rude. Thanks alot and if you think I can help you with something don't hesitate to ask.
    Aug 2015
    Belarus Molodechno
    Write this mod
    -----------> WinOLS_ (MOD_DPF OFF)_508388_CS OK_(DizelDiag).rar
    pass you know
  7. The Following User Says Thank You to unnamed11112007 For This Useful Post:
    h0m3s1ck (10th August, 2018)
