1.9 TDI DTC off? can you help me?
    Top Poster + Tuningfreak86's Avatar
    Dec 2013
    Germany
    Default 1.9 TDI DTC off? can you help me?
    Hi i hafe some problems with dtc fails..
    Fail codes
    4633
    4562
    40E2
    44F7
    406B
    4680
    can you Make off this fails?
    thank you
    Dec 2013
    Germany
    Help?
    can no help me?
    Top Poster zapdus's Avatar
    Jan 2017
    Hey, better post codes with vag com or sth
    Like PXXXX
    Apsik's Avatar
    Mar 2015
    just behind you
    I decoded his codes - they are HEX
    ... but watch this:
    17971 - Quantity Adjuster (N146): Lower Limit Reached
    17762 - Modulating Piston Movement Sensor (G149): Electrical Malfunction
    16610 - Throttle Pedal Position Sensor (G79): Implausible Signal
    17655 - Needle Lift Sensor (G80): Open or Short to Plus
    16491 - Manifold Absolute Pressure (MAP) (G71) or Barometric Pressure (BARO) (F96): Signal Low
    18048 - Internal Control Module: EEPROM Error
    Tuningfreak86 - you should FIX this car first.
    If you find my post helpful please hit Thanks button.
    You can also hit Reputation button if you are kind enough.
  5. The Following User Says Thank You to Apsik For This Useful Post:
    bobolin4o (11th August, 2018)
    Dec 2013
    Germany
    the Problem is, the car hafe not failures with the original File.
    The tuningfile hafe problems and give the failure codes out.
    Can take off the failure output?
    thank you
    Jul 2012
    Quote Originally Posted by Tuningfreak86 View Post
    thank you
    the problem is the file you've edited .. I suggest you do a new job and most likely you will not need to delete any of the dtc
  8. The Following 3 Users Say Thank You to mario38 For This Useful Post:
    Apsik (12th August, 2018), bobolin4o (11th August, 2018), morgano (11th August, 2018)
