copy and paste on this ecu just not so possible, eeprom has to be edit before writing as I know...
but I´m the wrong person can´t help you...I´m sorry...
Hello Guys,
I am in the deep mess with a 2013 touareg v6 TDI I attached the origianl ecu photo and the donor ecu. Original ecu died but i read it well before.
I have loaded the data to the donor but it comes up as internal memory error.
Car cranks but wont start.
Can someone tell me what to do???
Thx
BALI7605 (10th August, 2018)
HI! I make immo off for you. try if car start normal. but problem is in your hw... is not same.
BR!
MicroORI_immo_off.rar
i have immo off on the car at the moment but auto stop and start doesnt work and have engine light on
do you think if i get the rigth HW number cloning will work?
Yes, if you have full read from old ecu (fls + eep) so you can write.this on donor ecu and oke.
Or: if you cannot write eeprom, just do like this bellow:
Some old ecu wil reprogram eeprom if you write correct fls. Plug ecu in car, switch on 10sec. Switch off switch on and car start
Regards,
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
