Results 1 to 13 of 13
    Mar 2018
    Default kess v2 protocol not found error after sd card format
    please HEEEEEEELP
    i hve a problem after my kess v2 had wake up error i tried to formate sd card
    but the new problem was protocol not found
    can any body help me please!
    Jun 2013
    EU
    It depends on your kess version.
  3. The Following User Says Thank You to morgano For This Useful Post:
    liban11 (9th August, 2018)
    Mar 2018
    Quote Originally Posted by morgano View Post
    it's red kess v2 master
    5.017 version
    chinese version
    Jun 2013
    EU
    You can find on the forum a thread with a sdimage and a tool to change cid of your sdcard so you can match sdimage to your sd and make your kess a runner again.
    mancioks's Avatar
    Feb 2017
    Germany
    Search not find sdimage in DK :/ I need this tool for other thing. If You niw how to find that thread i would be thankful.
    Mar 2018
    i searched a lot but no way,i had no result
    Mar 2018
    i found an old sd image but not work steel protocol not found error
    Jun 2013
    EU
    You know cid of your sd card?
  10. The Following User Says Thank You to morgano For This Useful Post:
    drdahmani2 (11th August, 2018)
  11. #9
    Mar 2018
    Default Finally! this is the solution
    problem solved
  12. The Following User Says Thank You to liban11 For This Useful Post:
    shamoosal (1st November, 2019)
  13. #10
    Jun 2013
    EU
    Quote Originally Posted by liban11 View Post
    finally this is the solution for kess 5.017 and ktag 7.020 sd
    if i helped thanks and rep
    there is no pass
    No pass needed to download the rar file, but to extract it is needed a password. Also no info about what CID is needed in SD card to make this images work. Useless post as is.
  14. #11
    Oct 2011
    Germany
    Create a new SD-Card for Kess 5.017
    https://www.digital-kaos.co.uk/forum...-a-new-SD-card
  15. #12
    Nov 2019
    Default Hi
    Sorry what was the solution? I have done exactly the same thing.
  16. #13
    Jan 2019
    Best Country of the world, GR
    Quote Originally Posted by shamoosal View Post
    Try this solution...
    Quote Originally Posted by bergbahn View Post
    kess 5.017 SD Card
    Post #268
    downlod link from Member morgano
    https://www.digital-kaos.co.uk/forum...=1#post3645247
    Password is:“ByMorgano@DK”
    give thanks and reputation to the post #268 or read post #375 https://www.digital-kaos.co.uk/forum...=1#post3682611
