Results 1 to 6 of 6
Thread: zgemma help
    Jul 2011
    Default zgemma help
    hi my zgemma box only works for a few mins then says no signal was working fine subs are ok changed splitter and wire but still doing the same can anyone help plz
    Jun 2018
    Is it overheating ?
    Had a receiver with similar behaviour like yours and it was running too hot. Try to check if it is hot and just temporarily remove case and put a fan on it to see if heat is the problem.
    Jul 2011
    thank you looks like it is over heating is there any repair for it or is it time for a new box
    joe516's Avatar
    Mar 2008
    manchester
    Quote Originally Posted by gof1 View Post
    new box...……...
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
    Jun 2018
    Indeed there is no fix. You can try to use a fan powered from 5volt from your receiver. Be carefull where you take those 5Volts because you don't want to take power from chipset for example. Would be better to take 5Volts nearest from source.
    Don't know zgemma receivers but it might help to remove heatsink and put new heat conducting solution because the one which came from factory is probably damaged from heat and is quite hard now leaving your cpu without contact from heatsink thus resulting in poor heat transfer. Let's hope this receiver has some kind of heatsink which can be removed without desoldering.
    DK Veteran lincsat's Avatar
    Jun 2008
    No signal is unusual for Cable, usually they pop up a "Tune Failed". It's common on a poor Cable signal. You could have a dodgy tuner, you can also try another PSU.
