Results 1 to 9 of 9
    Mar 2014
    Poland, Lublin
    Default Grand Vitara 1.9 DDIS edc16c3 TVA off
    I need to turn off TVA. Car has df226 fault stored and goes into limp mode. Throttle replaced and wiring checked, everything ok so i guess ecu is faulty.
    SW version: 503133
  2. The Following User Says Thank You to kudlacz For This Useful Post:
    zigi2006 (16th August, 2018)
  3. #2
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Should work
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  4. The Following 2 Users Say Thank You to Ignasvw For This Useful Post:
    Faraday (2nd November, 2018), kudlacz (13th August, 2018)
  5. #3
    Mar 2014
    Poland, Lublin
    Your solution works great!
    Big thanks
  6. #4
    Member goosebartek's Avatar
    Jan 2012
    Mosina
    I have the same problem in Suzuki Vitara 1.9 DDIS 2008 ....
    I can ask for remove this sane problem ? DF226 and limp mode...
    DF226 its probably P0120
    regards
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by goosebartek View Post
    regards
    i see someone is already tried to remove something from your file because dtc missing
    here you go the right solution
  8. The Following User Says Thank You to Ignasvw For This Useful Post:
    goosebartek (13th August, 2018)
  9. #6
    Jan 2012
    Mosina
    Quote Originally Posted by Ignasvw View Post
    Hi DPF its remove...
    I check file and send info
    regards
  10. #7
    Jan 2012
    Mosina
    all ok
  11. #8
    Oct 2012
    I have an identical problem. Suzuki edc16c3 tva error Df226. Anyone help? Regards.
  12. #9
    Oct 2012
    no one help ?
