If HW and SW are the same, this will suffice flash + eeprom.
Treat the best to copy the whole.
Hey guys.
I have a Peugeot 206 with EDC16C3 where I think ECU has some problems when hot and want to make a swap with another EDC16C3 to test.
I have full BDM read of the old ecu and will do the same on "new" ecu.
Do I need to copy EEPROM + Flash + MPS or only Eeprom+Flash ?
Thanks in advance.
jaxone (14th August, 2018)
Bosch numbers are not the same , but both ecu's are EDC16C3.
Will check the "new" one when it comes, to be sure same MPC.
I was thinking more at the CS between flash / MPC / eeprom.
Working with Ktag original.
upload bosch number orginal ecu
FILE SERVICE
Tested only with Eeprom and Flash , no go.
So I had to make full restore to new ECU. Car starts and drives so ECU is ok.
Still cutting power while driving , so next step is BSI.
Thanks everyone for input.
upload flash maybe whos cut dtc......
FILE SERVICE
Here is the Flash.
It feels like 12v is cut off from ecu after car gets warm... so I don't think flash is the problem.
P0183 - Fuel Temperature Sensor A Circuit High Input
P0382 - Glow Plug/Heater Circuit B Malfunction
P1666 - Unknown fault code
P0343 - Camshaft Position Sensor Circuit High Input
P0337 - Crankshaft Position Sensor A Circuit Low Input
