You need to open ecu, read flash 29Fxxx with external programmer.
You have original file read via obd, you need to fix the file (obd read is usually partial) and reprogram flash with external programmer.
Hello DK's
Maybe you can help me ?!
Have my engine control unit with a wrong software dubbed
ecu does not let me do anything, neither a recovery or anything else, and of course the car does not start!
how can I play the chip directly? which one is that and can I do it with kess v2?
it's about a
Bosch 0 261 204 420
DME 1 430 940
Control Module
I hope you can solder directly and re-record
Kind regards
TheDevil667 (15th August, 2018)
Try write original back and choose slow.
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
I try so much , Recovery by kess , dosenīt work !
Temperature display on the speedometer is on stop as if it were still programmed the ECU ?!
've really tried everything, even with Galetto v54, normal, boot mode, Bdm I know myself too little because I do not know where in my ECU I should solder the cables or pins!
have google since yesterday in continuous operation and search, find a lot, only my controller is not really there!
if you have pictures or a really good guide except chip, I can not, the equipment is missing!
would be really grateful
Kind regards
ryan351 (29th October, 2018)
Gesendet von iPhone mit Tapatalk
Do Not Forget
THANKS & REPUTATION !!
Kind Regards
Tried you a programmer?
IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
on the backside you have 29F200 itīs flash... fastest way will be desoldering and reading, with a programmer... I know you donīt have it...
Iīm not sure but over obd you will maybe solve it with WinKFP...INPA... NCSexpert.. but for this you need K+DACN cable... but you will find it fast on net...
Nothing you can do via OBD. Recovery just by desoldering PSOP flash and reprogramming via external programmer.
You can back to life this ECU with WinKFP advanaced mode. Read UIF and write corresponding assembly number software.
this is flash and one bad progrmisang and any tool no programing this ecu by obd with recovery function. Use K-tag or programmer, I use beeprog, desolder flash programing correct flash and car start.
FILE SERVICE
BMS46 has no boot mode. You only solution is soldering. Pay someone to do it. There should be enough chiptuners in Austria
