Results 1 to 7 of 7
    Aug 2018
    Netherlands
    Default CMD OBD possibilities
    Hi Guys,
    I'm thinking about getting the OBD tool from CMD flash.
    Now I see in the OBD carlist (https://www.flashtec.ch/index.php/pr...obd#obdcarlist) some models can be read/written by OBD and some by K-line.
    If I not wrong, some car models have a k-line pin in the OBD socket, so these cars can be done completely by OBD without removing the ECU to the bench, right?
    So, what does it mean in case it is mentioned in the CMD OBD car list. All cars that are mentioned with K-line can be done completely by OBD?
    Thanks, greets, Dima
    Aug 2015
    that is OBD car list and yes, all cars from that list can be done by OBD
    toyolex 3
  3. The Following User Says Thank You to dtip For This Useful Post:
    ChipEde (16th August, 2018)
    Aug 2018
    Netherlands
    Quote Originally Posted by dtip View Post
    Thanks for your message!
    It only means that communication is done by kline, others by can line, both through obd, some cars dont have kline connected from ecu to obd, so you might need to do the connection straight to ecu connection pins.
  6. The Following User Says Thank You to juse For This Useful Post:
    Aug 2018
    Netherlands
    Quote Originally Posted by juse View Post
    yes, that's what I thought, thanks for the confirmation.
  8. #6
    N/A
    Insignia 2010 with tprot as well?
    HW:
    SW: 1037A50862
    VIN nr.:
    SW ver.:
    Spare:
    Engine:
    HW Ver.:
    SW upg.: P564_OA4
    Installation:
  9. #7
    Spain
    Hi M8,
    Both kline and canbus are possible through obd port, newer cars will work using virtual reading files from CMD server.
    Regards.
    Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
    Worldwide assistance.
    All brands, All vehicles, All files.
