Results 1 to 4 of 4
    Default Eurovox EX1100 USB Flashed/signal but no channels
    Hi All,
    I am pretty new to this but think I have managed to do things right.
    I bought a Eurovox 1100 USB and flashed it with the latest firmware. I have 28% signal, but when I do a powerscan I pick up no channels. I took the box to my friends house who also has a Eurovox (older model) My box still stated that it had 28% signal there. We did a scan just on 6952 and picked up all the channels. Does this mean I have a signal issue at my place?? Is the signal bar reliable?
    Thanks in advance.
    dasteph's Avatar
    Nov 2008
    north east
    take it back home and try it as you appear to have the correct symbol rate for your area and as it is now picking up all aviable channels, if you are using a splitter take it off and put the cable into the back of your eurovox when you try it.
    Default Help
    I have a similar problem, 28% signal but it find no channels. any ideas?
    Member big-g's Avatar
    Nov 2008
    ive got a ex5000 that ive had for about 12 months works fine,so ive bought a ex1100 usb it came today flashed it with latest firmware did a powerscan nothing,tryed a few times but nothin,so cleared data did a deep scan picked 173 up tv and about 30 radio still had a few missin so i turned the box off then back on did another deep scan without clearing data and it found the rest!!!!!normally on ex5000 power scan finds most then deep scan finds the rest but on ex1100 it seems to differ!!!!hope this helps mate
