Results 1 to 8 of 8
    Nov 2017
    Romania
    Default VW T5 Hotstart trouble
    Hello, can somebody please help me find the starting map in this dump? it really ate my whole morning ! Will not forget the magic buttonS!
    1.9 TDI AXD 131 Cp
    0281011568
    371973
    070906016AJ
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by haidumartocian View Post
    1.9 TDI AXD 131 Cp
    0281011568
    371973
    070906016AJ
    no hot start problem in your dump.
    fix the car
    DSG TUNING
    File Service
  3. The Following User Says Thank You to maajkii For This Useful Post:
    haidumartocian (16th August, 2018)
    Nov 2017
    Romania
    Thank you for the quick reply! But can you share the info ? where the map is being located ? big thanks!
    mancioks's Avatar
    Feb 2017
    Germany
    Map located: EEEDE. But there is nothing to fix there.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    1.9 TDI AXD 131 Cp
    0281011568
    371973
    070906016AJ
    Your hotstart fix
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  7. The Following User Says Thank You to Ignasvw For This Useful Post:
    haidumartocian (17th August, 2018)
  8. #6
    Aug 2011
    i also need help with hot start. car is t5 2.5tdi axd
    Bosch Hardware Number: 0281011568
    Vw Software Number: 070906016AJ
  9. #7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Here hoststart
  10. The Following User Says Thank You to Ignasvw For This Useful Post:
    grigoregtc (15th October, 2019)
  11. #8
    Aug 2011
    Thank you. tested and all is ok.
