Results 1 to 5 of 5
    cubica1's Avatar
    Feb 2012
    Serbia
    Default Fiat Doblo EDC16C39 need DPF_OFF tested solution
    Hi freiends,
    if somebody can disable DPF from this file, I need tested solution because the car going to other town.
    Thanks in advance,
    regards,
    cuby
    Doblo 1.9 MJTD 88KW 2006y
    EDC16C39
    HW: 0281012853
    SW: 1037388121
    Sep 2016
    tested, write.
    FILE SERVICE
  3. The Following 3 Users Say Thank You to voltechcar For This Useful Post:
    cubica1 (16th August, 2018), morgano (17th August, 2018), pike (17th August, 2018)
    cubica1's Avatar
    Feb 2012
    Serbia
    Hi my friend,
    many thanks, I'll test and report this night...
    This was the most strong pass I have ever seen
    Many THANKS,
    will back soon
    regards,
    cuby
    .....should I disconnect sensors??
    Sep 2016
    My files have only strong pass because people download files and use pc to decrypt files for free, I edit files for one user not all. You no need disconnect sensor but I emulated of course.
    FILE SERVICE
  6. The Following 2 Users Say Thank You to voltechcar For This Useful Post:
    cubica1 (17th August, 2018), morgano (17th August, 2018)
    cubica1's Avatar
    Feb 2012
    Serbia
    I think this should be fine!! Before of all I have reseted DPF, correct CRC and write file...drive car for approx 20km...no DTC..looks fine.
    Once again an BIG thanks to @voltechcar,
    regards,
    cuby
