Results 1 to 4 of 4
Thread: zgemma box
    Leeds
    Default zgemma box
    New to the cable world, when I set up a zgemma box I will need external drive can I use 8 or 16 GB USB stick as external drive?
    joe516's Avatar
    Mar 2008
    manchester
    Quote Originally Posted by Adam_UK View Post
    8 or 16 GB USB stick is ok m8 to record to the USB I have a 4GB
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
  3. The Following User Says Thank You to joe516 For This Useful Post:
    Adam_UK (19th August, 2018)
    DK Veteran lincsat's Avatar
    Jun 2008
    You can setup without but if wanting to record to the USB, remember the 4GB file size limit in the FAT file system.
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by lincsat View Post
    Yep. However the drive can be initialised through the Zgemma menu & will format the drive to ETX3 or EXT4 file system.
