Results 1 to 2 of 2
    Nov 2010
    Default Jeep Grand Cheeroke 2011 DPF off
    hello
    have Jeep 2011 3.0 crdi
    Edc17c49
    tried to fap
    This ECU have swich to dpf
    but after 20-40 km have dtc P244A- dpf pressure sensor But car drive nice
    This DTC was removed also
    Can somebody can advise about this ECU May be this ECU have more then swich??? Want to understand this ECU
    pike's Avatar
    Sep 2013
    Exclamation Jeep Grand Cheeroke 2011 DPF off
    Where did you get that these two values
    "$28BAAC";"D-component via pedal value / Differential factor Kd = Td/T1"
    "$28BCE0";"Kd for exhaust gas volume DT1 filtering for minimum charge monitoring of the PFlt"
    are a dpf off switch?
