Results 1 to 15 of 15
    Dec 2017
    Default 2017 toyota hilux dump 83800-fc530
    hii guys..can someone help me with dump..cluster come already spoil with eeprom..
    eeprom c66 mini..
    cluster part no 83800-fc530
    thanks in advance
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    What happen to the original dump??
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
    Is it miles or KM? How do you know eeprom or dump is damaged?
  4. The Following User Says Thank You to Smurf786 For This Useful Post:
    muzri360 (22nd August, 2018)
    Jan 2016
    try and report
  6. The Following User Says Thank You to sagie For This Useful Post:
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by sagie View Post
    try and report
    Hi mate, thanks for help here, however to use your file people have to add BIN format to your file and swap it.
    I corrected your file, here it is.
    Good Luck All!
  8. The Following 3 Users Say Thank You to jomberykaso For This Useful Post:
    muzri360 (22nd August, 2018), sagie (21st August, 2018), Smurf786 (21st August, 2018)
  9. #6
    Dec 2017
    eerprom come broken..i will try this dump n report..thanks
  10. #7
    Dec 2017
    sagie your dump for manual transmission..my car auto transmission..can someone get me dump auto transmision and 4000km..thanks
  11. #8
    Jan 2016
    if i remember correctly, that hilux was automatic with screen on centre dash for reverse
  12. The Following User Says Thank You to sagie For This Useful Post:
  13. #9
    Dec 2017
    i try it but the gear light wont turn on
  14. #10
    Dec 2017
    i try this file its work but pre crash and lda malfunction turn on..can someone remove this pre crash and lda malfuntion also turn 5500ml to 5000km..thanks
  15. #11
    test.................................
  16. The Following 2 Users Say Thank You to nikz For This Useful Post:
    muzri360 (22nd August, 2018), sagie (22nd August, 2018)
  17. #12
    Dec 2017
    its works perfect..thanks nikz and DK member..you all save my day..thanks a lot
  18. #13
    Dec 2017
    Hi, I have the same problem with hilux 2017. I change the dump and now the dashboard does not show the different automatic gear box positions (P - S -R -D). How can I do? Thanks
  19. #14
    Sep 2013
    Quote Originally Posted by dcenteno View Post
    Did you test my last file posted for you in your own thread?
    Check this link:
    https://www.digital-kaos.co.uk/forum...=1#post3802687
  20. #15
    Dec 2017
    Hello, please I need a dump (98000 km) for Hilux 2018 4X4 Automatic. With Spanish language . I am From Argentina.
