Hi col,
Thanks for your concern. I followed Josh's instructions, but was not successful. I may have slipped up somewhere.
However, RSwire helped me out, and I'm now running fine.
Thanks to you all. I hope to return the favor someday.
send me you code licenese pleasse
PLEASE HELP
DDDL 6.45
TOOL ID: DM4WB9LL
REGISTRATION CODE: ?????
Thanks joshplianfield, works 100%, I have two questions, running DDDL 6.45, appears (NXULNK32 failure initialization error 275, because.
When I install and run DDDL 4.7, the following dialogue box, because.
Detroit Diesel Diagnostic Link has encountered an unexpected event. In order to maintain data integrity Detroit Diesel Diagnostic Llink will now shutdown.
An incident report has been generated and stored in
“C:\Detroit Diesel\Drumroll\Technical Support\Incident Reports3.IncidentReport”.
Message: “DataInterface: 05125: No valid licence file found (004)”
on dddl 7.4 I experience the same thing on my older hp laptop w/xp pro sp3 and I just got another pc (a cheap netbook) w/win xp home and it worked fine.
try downloading this and just double click it and say "ok" when it says add to registry then try to install and open dddl 7.4 again
http://rapidshare.com/files/423353321/dddl.reg
as for dddl 6.45 that is just a error because you are not hooked up to a truck yet,pay it no attention.
josh
Hi joshplianfield,
Without improvements in DDDL 7.4, the message continues after dddl.reg
Hello there, excuse me guys, any of you got the DDDL 7.05. I would appreciate if you shate it with me. PM me if you do. I will share the ET 2010C or 2011A as soon as available.
Thanks in advance.
DDDL 7.05 is in this thread http://www.digital-kaos.co.uk/forums...7-04-a-161678/
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
please key ID DMXC4JJL, thanks
