Page 8 of 40 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 591
  1. #106
    DK Veteran superc0's Avatar
    MEXICO
    hi members, i have a fresh so( windows xp sp3 because a have troubles with my laptop) and i installed all again, but i cant isntall dddl 7 03, when the isntallation begins, this stops and send me a error code, i verfy:
    windows installer
    net framework
    and others things but i cant install it
    some ideas????????
    SOFT FOR ANDROS BENCH 6330 HELP PLZ.
  2. #107
    Member Texas149's Avatar
    USA
    OK guys almost recovered from my lappy crashing....got almost everything back up and running but my detroit software is whoopin me bad...I can't seem to get the crack to work. Every which way I have tried has been absolute failure. Here's the info DDDL 6.44 Tool ID : DMZMVKGL DDDL 7.03 Computer ID: E5-29-EC-96-34. If someone could get me the keys I'll do backflips all the way through the shop!!
  3. #108
    Quote Originally Posted by Texas149 View Post
    TRY
    DMZMVKGL = 1062121684
    E5-29-EC-96-34 = 0C-DF-05-80-3D
  4. #109
    USA
    I need to program a spare ECM to perform the turbo actuator adjustment routine. Anyone got the files?
  5. #110
    You need DRD/DDRS for that Bud...
  6. #111
    Default ddrs
    does anyone know where a hard working mechanic could find ddrs v7
  7. #112
    DK Veteran RSwire's Avatar
    your girlfriends house
    Quote Originally Posted by chad.socal View Post
    Since the search button is so hard to find I did it for you,
    check this thread http://www.digital-kaos.co.uk/forums...highlight=ddrs
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
  8. #113
    USA
    Quote Originally Posted by softguy09 View Post
    Yes I am aware of this. Just need the actual files to program with
  9. #114
    does anyone have key for
    dddl 6.45 DMQS2C90
    dddl 07.05-01301-00000 id D4-F7-87-C9-D4
    thanks in advance
  10. #115
    Quote Originally Posted by 68iou1 View Post
    dddl 6.45 DMQS2C90
    thanks in advance
    6.45 = 21833712
    7.05 = 3D-01-6E-DF-DD
    enjoy my friend
  11. #116
    Just got a hold of kg witch can set some levels for DDDL 6.4.
    Anyone knows is there are difference between registration codes made with level 1 and level 2 or what do they for?
  12. #117
    can anibody helpe I need the key for dddl 6.45 my pc id dmctby00 thanks in advance
  13. #118
    Quote Originally Posted by luomgofe76 View Post
    m8 check your pc id
    getting wrong tool id value
  14. #119
    ENJOY.
    YOUR KEY = 6298226
    Next time post pcid in caps.
  15. #120
    hello friend!
    could you help me with this key?? to ddl 6.4
    DM9ZPG10 THANK YOU
    Quote Originally Posted by RSwire View Post
    ENJOY.
    YOUR KEY = 6298226
