Results 1 to 8 of 8
    Aug 2018
    Default RENAULT clio 2 cleared dont work.
    Hi,the car had a side crash and i have cleared the airbag bosch 0285001537, whith carprog.I try several dumps but it still apears the light in dashboard.I have observed that the time to swith on the ligt is diferent with each dump.I ask for help and i leave mi crashed file if it helps.Thanks
    Jun 2017
    Brazil
    Default clio 2 cleared
    here friend, test and report
  3. The Following User Says Thank You to Diogo Mello For This Useful Post:
    sergioescty (22nd August, 2018)
    Aug 2018
    You file . If help press Thanks . pass pm.
  5. The Following User Says Thank You to Blade84 For This Useful Post:
  6. #4
    Oct 2013
    Czech republic
    cleared
  7. The Following User Says Thank You to HLAVICKA11 For This Useful Post:
  8. #5
    Aug 2018
    Unfortunelly, these dumps dont work.The light swith on after 3 seconds to turn the key.Sure the Airbag ecu must be dead.Thak for yours dumps.
  9. #6
    Aug 2018
    Do you have diagnostic interface "clip" ? . What erros are ?
  10. #7
    Member Tecnicks's Avatar
    Portugal
    Do you have errors in the airbag unit?
    if you do not check the motor unit.
    if you do not have any errors cause some, turning off some sensors or actuators, checks if the unit has taken over the errors, and then deletes them.
    Do this two or three times. provoke and eliminate the errors and try to follow.
    After me the feedback
  11. #8
    Aug 2018
    Thanks i have bough a clip interface, when it arrives home i will try to clear the fault codes.
