Do you check DPF service Counter that usualy set for around 250 000km? It is in the service reset list where engine oil, brakes,brake fluid etc is resseted!
Hello,,
Need help wih e70 ed16cp35 dpf off in engine ecu no fault ,but in navigation display filter problem after engine works 10min
DjRomeoR (22nd August, 2018)
Write ori back and see dtc's mayne 1 sensor on the dpf is damaged. So you need dpf + dtc off
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
I had same situation, no dtc.
I cutted dtc from dtc table from all sensor aboved dpf and solved
Sedat Garip
Belgium
With Kind Regards,
Here DPF OFF solutions without disconnected sensors. Reset DPF in Rheingold before writing.
Try this. Can disconnect sensors.
are a long way to disable screen message,you have to disable CAN BUS from ecu to navi.
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
problem in differential pressure sensor, good emulated and problem gone, check parameters....
FILE SERVICE
