What ecu is inside? If edc16 u need only 2hyst maps set to 0.
Will hear your opinion about which solution is the best.
would like to remove egr
I have read with kess v2
1st solution
Remap with titanium, by changing the value for egr. so it's closed all the time.
2nd solution
Removing egr with ADS, (EGR OFF SWITCH AND DTC OFF)
This is all new to me, just a beginner who wants to learn more about this.
So if anyone wants to take a look at the files I have attached and tell me which solution to try with?
Thank you very much in advance.
Help = Thanks + Reputation Button
Equipment I use
DIAGBOX 7.83 ( soon 8.55 )
TDB007
KESS V2 - clone Still learning
KTAG - clone Still learning
MJeppesen24 (22nd August, 2018)
1st if you want someone to rate your work, you must also upload the original file
2nd In this case you must sets 0 in 4 hyst maps. In attachment pictures, please look. all of them set to 0
It is EDC16C39
do you want to check the files for me? If the solutions I have made are something that can be used? or is it just garbage?
here is the org file
Thank you for your help
Equipment I use
TDB007
no one will check if egr has been removed?
Equipment I use
TDB007
1. ERG_OFF REMAP - will not work at all.
2. ADS is also shit, too much DTC delete.
Use hysterise map for closing EGR in EDC16, mack0r alrady give u solution.
Is this the right solution?
Best regrads
Equipment I use
TDB007
Friend...
4 Egr hysteresis are ok
But why you change maps 1E325E and 1E332A?
4 Egr hysteresis maps is enough for Egr off.
MJeppesen24 (25th August, 2018)
