Results 1 to 9 of 9
    May 2017
    Default Navara DPF problem
    Hello everyone, I tell them to eliminate DPF physically, I am hollow, without ceramic. One person eliminated DPF and EGR + REMAP power. He turned on the DPF light again and limited himself to limited power. I do not know what to do now. Who can help me please?
    Thank you very much.
    Aug 2018
    Russian Federation
    This original file is bad!
    Babos's Avatar
    Mar 2012
    Quote Originally Posted by QuantumECU View Post
    Why you think that? I not see problem in original dump, just problem in mod file there is not correct off dpf and egr about power is ok.
  4. The Following User Says Thank You to Babos For This Useful Post:
    Cristian256 (23rd August, 2018)
    May 2017
    How can I solve my problem? I do not know what to do, I spent money. Thank you very much.
    soundnavigator's Avatar
    Sep 2010
    The file is ori. Better solve the problems 1 by 1. First get good DPF + EGR OFF solution, then make tune ... or ask tuner who made it.
    BR
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
  7. The Following User Says Thank You to soundnavigator For This Useful Post:
  8. #6
    pike's Avatar
    Sep 2013
    Hi, it's possible that you do not have any DTC in diagnostics.
  9. The Following User Says Thank You to pike For This Useful Post:
  10. #7
    May 2017
    Yesterday I did a scanner and there is no DTC. Only the DPF light is on and quite limited in power.
    Thanks for answering.
  11. #8
    pike's Avatar
    Sep 2013
    What diagnostic codes were with the original file?
  12. #9
    May 2017
    I had P2279 that was a half hose apparently loose and P2478 that disappeared later.
