Device type: M
FW version: 4.036
Serial Number: K10033818
Custome Code: C7514
Group Code: C7514
Hello
Since a few days ago I am trying to repair my kess v2 v4.036. I searched through all the posts for the sd files and possible solutions. I have tried with new sd card, formatted with non-Windows programs. sometimes, he tells me that the protocol is not valid and sometimes he tells me that the ecu is unknown (this happens to me with TEMIC DQ250). Can someone help me?
Thank you
Device type: M
FW version: 4.036
Custome Code: C7514
Group Code: C7514
No body can help me?
Use this software update on internal SD card
https://mega.nz/#!ZN5wHKTC!yGtulxix4...Kg8uAHtiYb5e3g
wbr
EDIT: Here without pass ---> https://mega.nz/file/NEwnQKQY#Q2abCI...6XxMH_WXNePNmQ
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Geri12 (31st August, 2018), sergiobrdgz (25th August, 2018)
Geri12 (26th August, 2018), scsaba (22nd February, 2019), sergiobrdgz (25th August, 2018), Wilq188 (4th December, 2023)
Well, I installed and apparently the software works but I have to try it with the car yet.
These are the steps I have followed:
1. Deleted and formatted at low level the SD card.
2. Put the SD card back on the kess PCB.
3. Installation of the Kess software on the PC.
4. Connect the Kess to the PC.
5. Start the software.
6. Close and disconnect the Kess from the PC.
7. Put folders on the SD card of the Kess PCB.
8. Connect Kess to the PC and start the software again.
Have I done all the steps well?
zeen1974 (24th December, 2018)
For 4.036 no sense use other sw than ksuite 2.08 internet safe.
To have correct files on sd just redo the update with ks2.08 and the update folder with the families.
