Results 1 to 8 of 8
    rob h's Avatar
    May 2011
    Default Sim22 Ford Clone renew synch
    Hello guys,
    Ford Fusion 2004
    2004 sim22 ecu.
    Ecu is bad, fires bad on 2 cylinders.
    Customers asks, can it be cloned.
    Now i have been reading and came up with this.
    Cluster holds the keys, and is synched with ecu.
    Some sort of checksum, or synchro code.
    Some transfer 93c86, no start.
    Some transfer 93c86 and 29f400, no start.
    Dashboard holds a eeprom 24c08, it think.
    I dont have Ford VCM. Or ids at hand.
    So how can i get this car to start with another ecu?
    Any advice would be appreciated,
    Greetings Rob
    MartiLer's Avatar
    Dec 2016
    read dumps ecu
  3. The Following User Says Thank You to MartiLer For This Useful Post:
    rob h (23rd August, 2018)
    rob h's Avatar
    May 2011
    So, full reading flash and eeprom.
    From both ecus, and post?
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by rob h View Post
    You can read Flash n EEprom from old and write to doner if they aren't same part or
    Read eeprom doner ECU + dash to make sync (2 ECU had the same part)
  6. The Following User Says Thank You to lion0304 For This Useful Post:
    rob h (24th August, 2018)
  7. #5
    kiszka's Avatar
    Aug 2009
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  8. The Following User Says Thank You to kiszka For This Useful Post:
  9. #6
    rob h's Avatar
    May 2011
    We have trouble finding a matching used ecu.
    So i recommended that the repair the ignition ports.
    Thanks for the input guys!
  10. #7
    newone's Avatar
    Oct 2016
    Hello,fiesta with faulty sim22 ecu,i have found used with same part number,below dump from used and dash,can someone please make sync?
    edit
    solved with the help from user MartiLer
  11. The Following User Says Thank You to newone For This Useful Post:
    rob h (10th January, 2024)
  12. #8
    Apr 2017
    England
    Has anyone managed to clone???
    Press thanks + reputation
