Results 1 to 15 of 15
    Default sid801 immo problem
    hi, i need immo off file for siemens sid801 ecu for peugeot 307 hdi 2.0l, or virgin dump
    thanks for all
    i have 1 dump but car dont go over 3000 rpm
    or can i have pin from ecu dump
    May 2009
    hi
    post your dump
    is 93c56???
    regards
    Member Persia's Avatar
    Persia
    what is eeprom number?
    it's a 93c56 and will post dump today,
    busaman's Avatar
    suffolk uk
    you may have to telecode the car (pair bsi to ecu) i have had this before
    yes i would like to telecode the bsi but i have not the pin, and no vin too, the bsi is virgin,
    i read the 93c56 in ecu and post here if someone can read pin for me, i had doubt for reading in 16 or 8 bit, in the rar file i put the two files, thanks for help
    i think that the best way to solv ur problem is going on autorestore bsi
    i'll post procedure later...
    please, any suggestion
    benci1982's Avatar
    Slovakia :((
    trythis file, (16bit mode)
  11. The Following 2 Users Say Thank You to benci1982 For This Useful Post:
    Meat-Head (29th June, 2015), parazit85 (27th July, 2018)
  12. #11
    algeria
    YOUR CODE PIN:Y558
    ENJOY
    IF YOU NEED IMMO OFF TRY SWAP BYTE IN ORIGINAL DUMP
  13. The Following User Says Thank You to diagmoh For This Useful Post:
  14. #12
    thank you, solved
  15. #13
    Morocco
    benci1982 your dump is 100% good for 307 sid 801 and rmp 5500 tr/min
  16. #14
    Aug 2012
    thank you will test this one
  17. #15
    Meat-Head's Avatar
    Quote Originally Posted by autodiagfrom View Post
    yeah did you would like to know for leeching reasons?
