You opened with wrong driver.
Verstuurd vanaf mijn SM-G955F met Tapatalk
Guys look at this file. It has been extracted from a BMW 320d e46, EDC16 ecu. I opened the file using ECM Titanium and I saw some odd numbers see the attached Screenshots. If you look at the Injection at part throttle map it has Zeros in places that dont make sense at all and if you look at the Fuel During Acceleration Map it has negatives all over it and this makes no sense whatsoever. Car is starting but injectors behaving in such a manner that it cannot be operated. Can someone look at the file and advise if this map is okay or has something wrong?
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
your file is original, you have hardware issues.
Hahahahaha
Wysłane z mojego SM-G935F przy użyciu Tapatalka
DSG TUNING
File Service
that the ecu file (software) is fine! so if the car works shit is because of some mechanical (hardware) problem.
