Results 1 to 8 of 8
    Jul 2016
    USA
    Default Need Oscilloscope and help for checking CAN
    I’m looking for Oscilloscope for checking CAN lines. Also with the ability to have a saved “known good” graph to compare to the can waveform thats being read.
    Jan 2012
    EU
    Quote Originally Posted by borshch View Post
    If you want to study/test CAN lines, better to have also CAN analyzer.
    With it, you can see is bus alive, and what messages are transmitted.
    You can also generate your own CAN messages with CAN analyzer.
  3. The Following User Says Thank You to Aajii For This Useful Post:
    borshch (27th August, 2018)
    Jul 2016
    USA
    I’m looking for a type that I can check can lines on a vehicle for example: if there is corrosion on can wires or intermittent signal or faulty module messing up a can network etc
    Jan 2012
    EU
    One basic measurement is with multimeter:
    CANbus voltages (canh/canl) are approx. 2.5V measured betweem CAN - GND with multimeter.
    Normally voltage should be between 2.0 V - 4.0 V.
    If it is lower than 2.0 V or higher than 4.0 V, it is possible that one or more nodes have faulty transceivers.
    If you want to measure with oscilloscope, electronic oscilloscope is good.
    My opinion is that Rigol scopes has good price/quality
  6. The Following User Says Thank You to Aajii For This Useful Post:
  7. #5
    Nov 2015
    Actually, you need no example charts of can bus, since they are very clear and simple.
    It must be something like this:
    The "data" is difference between CAN-H and CAN-L signals, which must be about 2.5V
    "thanks" if i helped you is really appreciated
  8. The Following User Says Thank You to gljuk For This Useful Post:
    borshch (28th August, 2018)
  9. #6
    Jan 2014
    PICO SCOPE is what u should read about
  10. The Following User Says Thank You to Mr Mo For This Useful Post:
  11. #7
    Jul 2016
    USA
    Whats the minimum bandwidth MHZ for a scope for can data analysis ?
  12. #8
    clusters's Avatar
    Mar 2015
    Canada
    Any automotive scope is adequate, but like previously stated you can do it with a meter.
    You won't be able to decipher any detail in a CAN signal, just verify the operating voltages.
    First you need to know what system you are working on, UART, hi speed or lo speed CAN, PCI Bus, CCD Bus, one wire, two wire, they are all different.
    I repaired a Caravan no start dead dash CCD Bus problem with just a meter, the process is the same for all, disconnect modules till the bus goes normal.
    In my case, CCD Bus was 2.5V key OFF with the door open and BCM awake to control the interior lights, key ON it was 9V Turns out the HVAC panel had a cold solder joint on the ground pin, which caused the module to seek a ground through the CCD Bus taking down the whole van.
    Please DO NOT PM me asking for help.
    Post in the forum, that is what it is here for.
  13. The Following 2 Users Say Thank You to clusters For This Useful Post:
    borshch (28th August, 2018), speedy100 (1st October, 2018)
