tp7 cant obd to this with cloned tool , now its blocked read again with ktag and l will repair eeprom and flash and remove tuning protection and can read and write then was you using protocol 501 ?
Hi.
i need help.
i read Golf VI 2.0 TDI GTD tool kess, EDC17CP14.no STAR engine
write file DTC off when 70% error write. no recovery.
ECu is blocked, FANS cooler ON.
i read by ktag full after blocked.
i need help you recovery eeprom and flash.
Write full by KTAG.
frf file, flashing ecu by obd and start. Use avdi or vcp.
FILE SERVICE
only tools KESS, Ktag and Galleto.
i can use galleto obd??
No. You must restore your ECU by KTAG backup.
Compre Pcmflash, bom suporte trabalha duro.
Em erros de ventiladores, eu desligo o fusível e termino de programar.
Para obd uds eu também uso Mmcflahser, boa recuperação quando ocorre erro.
Virtual read 100 % ok.
server never fails.
write 2 files back by ktag and now tuning protection is off and can write your file ok by obd
to much china tools.....
FILE SERVICE
are you writing 1 at a time or trying full backup ?
