Your file. Hot start fix. Chk ok. Pass in pm
Hello everyone.
I ask for help please.
I'm struggling with the car all day.
Audi a3-1.9TDI.
AHF
1998
81kW.
Car has problem with the hot start. I read two eprom M27C1001, I put two new AM29F010B with different files modified with hot start fix, the car starts but it works with two cylinders and vibrates that is scary.If I write the original file in AM29F010B car works OK, but it's hard to start hot.
I ask for help to modify my file and calculate cheksum.
Thank.
bladymir (25th October, 2018)
Weird...
in that case I can not help
Thank you . The truth is that this is the first car I see that behaves like this, I do not know what to think, broken can not be because with its original file it works, with the modified file I'm afraid that the engine will break.
what gearbox you have and what coding in ecu?
FILE SERVICE
Coding 00002
Gearbox manual.
No fault codes
so if in automatic coding works on my file must works too. You write good file?
FILE SERVICE
I have tried at least 10 different files and it does the same but at different temperatures. In the last week I had an audi like AHF and it had coding 00002 manual. I am already fed up with this car.
coding 00001 not help.The same problem.
File original work,file modif.-not work.
You have other problem,not software.
