Results 1 to 5 of 5
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default Help me with EGR - DTC remove
    Hi people,
    I am unsucceeded with this car.. Bmw 525d f10 edc17cp45 ecu.
    Car have egr problem, i try with swiftec, no solution, again check engine light.
    I cannot find dtc table for remove the dtc bellow:
    Diagnose faults:
    257E00
    244800
    243300
    Generic DTC's:
    P046C
    P042E
    P042F
    Can someone help me and remove these DTC's?
    Attached file ori & egr off with swiftec
    Or is there someone they do always egr dpf off for me? Sent me PM ...
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    mislav88's Avatar
    Mar 2011
    your file with dtcs off
  3. The Following User Says Thank You to mislav88 For This Useful Post:
    sdtsedat (28th August, 2018)
    Sep 2016
    Quote Originally Posted by sdtsedat View Post
    Hi people,
    Diagnose faults:
    257E00
    244800
    243300
    Generic DTC's:
    P046C
    P042E
    P042F
    should be work
    FILE SERVICE
    sdtsedat's Avatar
    Jan 2015
    Belgium
    I try both files today,
    On file from Voltechcar, all was ok, and after ride 5km, again check engine light, i see measured values and egr will go up in percentage %
    @Mislav88: i write your file, egr don't move in measured values it will freeze on 0% and no more check engine light!
    Thanks you!!
    You have PM
    Thread Closed
    Sedat Garip
    Belgium
    With Kind Regards,
    Sep 2016
    Thanks you!!
    You have PM
    Thread Closed
    Yeap because I cut dtc no egr. You need dtc I cut dtc, easy and simple.
    FILE SERVICE
  7. The Following User Says Thank You to voltechcar For This Useful Post:
    pike (28th August, 2018)
