Your file
Hello everyone!!!
I have a problem with a Peugeot 407 SID 803.
I have canceled the dpf and the egr, and I still have several DTCs left. I have not managed to find Damos, Siemens PPD maps, it detects well in SID803a, but not in this, and these are:
-P0471: Discharge differential pressure sensor signal.
-P0299: Regulation of the Turbo pressure.
-P2565: Turbo pressure solenoid valve (is new and changed).
-P1429: Signal differential pressure sensor discharge.
-P1597: Circuit of the bypass solenoid valve, refrigeration circuit. Circuit open.
-P2031: Temperature of the rear catalyst. Cold engine consistency.
-P0095: Air temperature signal after the exchanger.
Coherence of the temperature output.
With my file I have achieved that P2031 and P0095 do not appear anymore. I have taken all possible data from my SID file 803 a, to compare, although there are very different sectors, and I would have the first 5 errors.
Could someone help with the dtc switch 1,2 ???
I already have an egr model and dpf off but I do not like it.
Really grateful, really.
Attached ORI as it came, with egr and dpf off, and my file with mappack and ols project.
Regards!!!
goyodesanctis (29th August, 2018), unicornux (29th August, 2018)
Hello mate!
I'm Alex from Spain and I have a Citroen C4 with 2.0 HDI engine remapped and having the P0095 issue after the EGR adn DFP canceled, how did you fixed it?
I dont have any tool to recover my files or something because I paid to a shop for the remap but they dont know how to fix the P0095
Thx in advance
PEUGEOT 307 2.0L HDI 136 CV SID 803
This is my MPC555 file, done by professionals. FAP and EGR are removed, there is no problem.
Another thing that I didnt say before,
-I dont know wich is my Engine computer
-I dont know how to read or load files to the car
-My car is dated on 2005 and the engine reference is RHR
I saw that forum entries before but is not providing any solution, or I am not able to understand it
I deleted the BYPASS error, everything is fine
in my file which I posted everything is done
I had P0095 and P1598, they are connected, I changed the air temperature sensor, and deleted error 1598 from the ECU file, everything works now
And do you have the MPC file to pull out of the ECU?
The problem is there, go to those who did, let them delete the BAY PASS error
