Results 1 to 9 of 9
Hybrid View
    Jan 2016
    Jumping Around the globe
    Default VAG MFD2 pinout for dump reading
    Hello,
    I was trying today to read the fis dump in order to get my VAG MFD code and i failed with my clone carprog that i bought years back.
    first of all i would like to know if its possible to get a dump reading while the radio is in "Locked" mode or should i plug it for 1 hour before trying to read the dump? I know i need to plug it for 1 hour to input the code, but is it needed to do so before reading the dump?
    Second, i found many pinouts for the same type of radio, and while i suspect they are all the same, i thought i would ask for help here.
    I will attach 3 different pinouts, some does not even mention the need of the 5V+...which i find weird. and not to mention that the carprog pinout is different than all of those.
    A guy i know have a vvdi prog, maybe i can try to read it with that, if not i think i have an xprog laying around somewhere.
    Please help clarify the pinout and the "locked" issue
    Codekuba's Avatar
    Aug 2018
    the radio does not have to be unlocked for reading ...
    I personally do "martech for radio code" and the reading goes on 3 wires
    Jan 2016
    Picture 2 and picture 3 both are from martech....and they dont show the same pinout. thats what confused me most
    Codekuba's Avatar
    Aug 2018
    I agree, one is with a martech clip and the other one with box3 ... for this radio jeat a few pinout
    Codekuba's Avatar
    Aug 2018
    show me a picture of your pcb
    Jan 2016
    here it is.
    I have a vvdi prog, since i am not trusting the carprog clone. always giving "verify error"
    Codekuba's Avatar
    Aug 2018
    Connect the cables as shown in photo 2
    SCL
    SDA
    GND
  8. The Following User Says Thank You to Codekuba For This Useful Post:
    Locker (29th August, 2018)
  9. #8
    Jan 2016
    So after i tried and failed with carprog clone and xprog, i went to a friend and got his orange 5.
    Now i cant power up the unit anymore...
    it was working when i unplugged it to go get the orange 5, now its dead.
    Fuse is good.
    Any idea what went wrong? Could i have corrupted the 24C32? does that cause the unit not to start?
  10. #9
    Jan 2016
    Still didnt find a solution to this, can't read dump (i get all zero's) can't write a file (stays all zero's), and the unit does not power up.
    any solution or i should replace the whole unit?
