READ EEPROM AND POST HERE FOR PIN CODE
hello all,
my astra H CIM moduel has failed from not sensing a turn all the way to showing squib flouts on the airbag,
After hours of tinkering i got a opcom and found out it was the Cim so i ordered a second hand one online, it has arrived but has not been cleared so im unable to program it because i dont have its security code, i have seen some of you talking about getting the eeprom do i need to get another peace of kit to do that or is it just time to bight the bullet and let a garage do it?
as so far on this car i have had to change the gearbox, clutch, filters and now got useless CIM what clears by airbag fouls and works but cant program it so that ££ down the drain at the moment.
Gaz
FVDI can read code from ecu
from CIM it can't
OPEL / SAAB EDC15M * PSG16 * EDC16 * EDC17 * DENSO * ACDELCO cloning / programming / resetting
just swap the board over inside usually works or the eprom 95320 also the pins beome loose on the board cold solder cause allsorts of issues the squib is fiddly but easy enough
Yes but ecu and cim used same code
