Results 1 to 8 of 8
Thread: C MAX 1.6TDCI
    Default C MAX 1.6TDCI
    I have a P0238 turbo pressure sensor i changed sensor tested wiring and tried another ecu always p0238 car drives fine so i was wondering if it can be removed... Ecu is 0 281 012 487 8m51-12A650-MD
    Nov 2011
    Romania
    here is your dtc off file pass pm
  3. The Following User Says Thank You to Tzepy For This Useful Post:
    djoko.k (30th August, 2018)
    Nov 2011
    Romania
    try to change boost control valve to solve the problem , whach real time data to se if you have demanded turbo presure
    P0238 still present...
    Any solution?
    double cheked wires and tried one more sensor got 5v on pin 1
    Nov 2011
    Romania
    please try this file pass is the same
  9. The Following User Says Thank You to Tzepy For This Useful Post:
    djoko.k (31st August, 2018)
  10. #8
    Thanks but car is gone...
