you can try: 00000000092500FE000F00E6902000000000 ,after change bytes long coding
Hi I have got a 2010 vw polo 1.6tdi, the ABS unit has lost its coding, is anybody on forum able to find out the ABS long code..
I have seen that some guys on here seem to be able to work out the code via the scan and vin number.
Here is the scan:
VCDS Open Controller ABS window Display>
VAG Number: 6R0 907379 R Component: ESP 8.2i front H04 0002
Soft Coding: Long Coding Shop#: Imp 790 WSC 31414
Extra: Geraet 31414
################################################## ##############################:dancing::dancing:
Address 03: ABS Brakes
Control Module Part Number: 6R0 907 379 R
Component and/or Version: ESP8.2i front H04 0002
Software Coding: 000000000000000000000000000000000000
Work Shop Code: WSC 31414
VCID: 4D96B276104A5E2C9F-8018
Advanced Identification
Flash Status
Misc.
Hardware number: 6R0 907 379 R
VCDS Info:
Labels: 6R0-907-37X-ESP82.CLB
AUTOSCAN INFO BELOW:
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.1
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: WVWZZZ6RZAU034427 License Plate: 34E323
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BC HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 8876
Revision: --H13--- Serial number:
Coding: 00114014000500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM16TID02103L906023BC 003007
ROD: N/A
VCID: 68D863E293E89B048C-803C
No ASAM data for: "EV_ECM16TID02103L906023BC" (VW36 *)
1 Fault Found
10162 - ROD - Unknown Error Code
- 00 [109]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 115727 km
Date: 2095.14.16
Time: 14:37:35
Readiness: 0100 0000
Cannot be reached
Address 08: Auto HVAC (J301) Labels: Redir Fail!
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 24 0660
Revision: 00 10 24
VCID: 3566FA969CDA36ECC7-8060
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 H HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0147 016102506
Coding: 25B02BBF08E12400923000003D2B0CD00000410F6006000020 0000000000
Shop #: WSC 00525 210 97013
VCID: 428C914ADD14915472-8016
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU022.01.1010459
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU021.01.1014688
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Coding: 000000
Subsystem 5 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 6 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU014.01.1010507
Coding: 08BC32
Subsystem 7 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU005.01.1016297
Coding: 08BC32
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00B H09 0018
Revision: -------- Serial number: 003DW00BJTS6
Coding: 003042
Shop #: WSC 31414 790 31414
ASAM Dataset: EV_AirbvAW10BPAVW250 A01001
ROD: N/A
VCID: 428C914AD514915472-8016
Subsystem 1 - Serial number: 3572SRB40000A71CC93C
Subsystem 2 - Serial number: 3582SRB40000A88D1199
Subsystem 3 - Serial number: 3516GRB402H9M2G71REI
Subsystem 4 - Serial number: 3526GRB401NAE7GP5S2X
No ASAM data for: "EV_AirbvAW10BPAVW250" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6R0 920 961 D HW: 6R0 920 961 D
Component: KOMBI H03 0205
Serial number: 00000000000000
Coding: 440A00
ASAM Dataset: EV_KombiU_DS_VDD_RM09 A04052
ROD: N/A
VCID: 377AF09E8ED6C4FCD5-8062
No ASAM data for: "EV_KombiU_DS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway
Cannot be reached
Address 25: Immobilizer
Cannot be reached
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667763636
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 26442DDA517C4D747E-8072
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10130
Shop #: WSC 31414
VCID: 2E54D5FAED8C053486-807A
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K7008460
Coding: 0100040002
VCID: 6BD21CEE8A1EB01CE1-803E
End-------------------------(Elapsed Time: 03:13)--------------------------
If I helped, dont forget use buttons reputation+thanks
Thanks Samux, it did not work. Thanks for trying.
