Genuine 'WinOLS,MagPro2X17 Master, VagCom-Vcds, Vag Can Pro-Vcp'
And 'Kess-Ktag' Red Pbc Ecu Clone User.
Professional Car Remapper And Ecu Calibration Expert From TURKEY
car start ok,all is ok but only dtc on....
everyone can delete dtc p0315 for ecu valeo v42?
regards
have same problem in Clio 4 ... P0315 active ....
Possible remove DTC ???
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
I have this problem as well, DF457 / P0315, Flywheel target programming, component is in poor condition.
I put new crankshaft sensor
I try re-learn of flywheel target but when I release accelerator at 3500 rpm this fault occurs
Any help with this problem would be great
If this post helps you,
Hit that thanks button!!!
I found out what this problem is all about.
The Flywheel target is an adaptation that the ecu does to learn the load signal and knock control limits, since this car is not equipped with a cylinder recognition sensor (camshaft sensor), the ecu must be re-adapted if flywheel is removed.
Problem comes in when u will be setting the flywheel target with the diagnostic tool, as most diagnostic tools cannot set the adaptation properly, even set with Launch or other equipment, the proper sequence is not done.
Solve by using Can-Clip.
Check for engine mechanical knocking as well, if ecu picks up any unusual knock then flywheel target will not be set.
Check throttle body is clean and zero adjustment is correct, because if airflow is incorrect then load image is not correct.
IF CAR RUN OK, I CAN DO LIGHT ENGINE OFF IF YOU NEED THIS SOLUTION
buenas tardes tienes que tener otro vehículo mismo modelo y motor ingresar con can clip ingresar a inyección modo de reparación salvaguardar los datos del calculador de inyección y sin salir de clip te conectas al vehículo que tiene el problema y escribes los datos salvaguardados del vehículo sin problemas y asunto arreglado luego controlas y veras que la falla no existe saludos.
mardude (14th August, 2021)
