Page 6 of 8 FirstFirst 12345678 LastLast
Results 76 to 90 of 109
  1. #76
    DK Veteran Walkinmyshadow's Avatar
    Nov 2008
    In a very strange place!!!
    Quote Originally Posted by pringle77 View Post
    can anyone help me fix my dreambox dm 500-c ,i cant access the info on this site
    Elaborate a little m8.. what is it you cant access??
  2. #77
    Nov 2008
    Total spoonfed newbies guide for anyone that has problems downloading
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
  3. #78
    HI IM COMPLETELY NEW TO THIS I HAVE A DREAMBOX 500S WHAT DO I DO NOW ?PLEASE HELP
  4. #79
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Quote Originally Posted by SCARFACESMOKE View Post
    Follow the tutorial.
    Although in order to get the channels on the sat box you will have to look into sharing from someone else.
    Not as simple as a cable box.
    Patience is a virtue.
  5. #80
    can someone help me. I have flashed the box with flashfxp (thanks for the download info here) and its worked with ip address etc.
    Im confused about how to go about transferring keys and scce and which ones from rapid sharing download do they go to??
  6. #81
    I must say thank you for creating such a forum with informative ideas and info. When flashing ur dbox with flashfxp u need to change the ip address of the box manually following after the router
    e.g.
    router ip - 192.168.0.1
    pc ip - 192.168.0.2
    dbox ip - 192.168.0.24 ( need to change this to 192.168.0.3) as well as making sure ur gateway and nameserver are the sam as ur router ip address.
    p
  7. #82
    Default dreambox 500
    hi, i am having problems flashing a dreambox,[have done 3 boxes with no problem]when 100% it says ERROR RESETTING LOCK_BITS anyone any idea what is wrong,is the box faulty? any help welcome.
  8. #83
    i can only feceive fta channels and sky sports does not appear on the list of available channels please help are there any new magic files i should be using
  9. #84
    DK Veteran atetruckrepair's Avatar
    THE JUNGLE
    Default dm500c
    ok guys i got a dm500c here in the us if i use your guide and files will it work on comcast? or do you know of any others? don't blow me off i'm open to here any input someone might have i put another thread in and got no response dvb seller say's it works over here i need some kind of help please
    thank's bill
  10. #85
    Jul 2008
    I suggest that you start a new thread with your query about using a DM500C with Comcast. It's lost in here.
  11. #86
    Slovakia
    yeah correct program will try another fxp file thanks
  12. #87
    I'm also unable to open your guide ,any help will be appreciated.
  13. #88
    V.I.P. Member Dreamer's Avatar
    Apr 2008
    Glasgow area
    Quote Originally Posted by lav1daloca View Post
    you need to unzip the file as it is in a zipped(compressed) format. You need to use a program that will de-compress the file. click this link to read this post from earlier in the thread.
    http://www.digital-kaos.co.uk/forums...848/#post46169
    Sometimes you will find the answer to your question just bye reading some of the other posts in a thread.
    The file is also a word 2007 document so if you don't have an upto date version of office then read this
    http://www.digital-kaos.co.uk/forums...tml#post127374
    The Falkirk Wheel. The only rotating boat lift of its kind in the world
  14. #89
    Hey shady, great thread no doubt I'll find it useful when my box arrives.
    [ame=http://www.youtube.com/watch?v=B7IOS9Yd4oI]YouTube - DREAMBOX 500C TUTORIAL[/ame] saw this on youtube judging by the name i take it it's yours & if so just wanted to know will that image i need to download work on a clone box ?
    I've seen these on DVBMonkey
    Dreambox 500c
    Eagle box 500c
    OEM Black box 500c
    and wanted to know the differences between them, which one to buy and if I'd need to download a different image or follow a different guide.
    Didn't post links to the boxes on purpose incase it broke forum rules.
  15. #90
    hi all. followed this very useful guide but as others have reported, am only getting FTA channels. There was some discussion early in the thread that seemed to conclude that the keys were perhaps outdated and that this was the cause of the blank screens. Can anyone tell me if this is the likely root of my problem, and direct me to the latest files if indeed there are any? I have attempted to read around the forum and will try a variety of solutions, but thought i'd just seek some advice before i spend another afternoon tangling myself up in half understood technological experimentation. many thanks!
