Results 1 to 3 of 3
    May 2008
    Default logging using dvblogger 2.6
    22222222222222222222222222222222
    Member dema2's Avatar
    italy
    Hi dear friend also in italy have this problem 9994
    i make this is necessary a HDD into the dream receiver
    connet to your dm receive in telnet
    i use D.C.C. 296
    send this en read the pid
    dvbsnoop 1 -n -1
    you can read the pid example italy 0x012d
    next send this comand
    /var/bin/dvbsnoop -b 0x012d > /hdd/log.bin &
    remember changhe the pid 0x012d with your G.B pid
    wait about one hour, next you find a soft that read this log i use logtool
    you find thid in playanueva sat forum italy, put your serial number put in the log fil than start
    if you have logged your ins for your serial card you can read this in precam you read your serial card, in D0420000 ....you have the ins with NTSITE2.3 and smartmouse you can send to your card use low voltage, you can burn your chip card
    i use 6 volts
    por any problem write me byby
  3. The Following User Says Thank You to dema2 For This Useful Post:
    libertate (27th September, 2013)
    italy
  5. The Following User Says Thank You to dema2 For This Useful Post:
