EX6000SD Nov 25th release
Just a couple of cosmetic changes,
1) "FAV Key" function added - Pressing FAV key while in Fav Channel List moves forward thru categorys, same as RIGHT key press.
2) "Recording File Name format" changed to Event Name/Date/Channel Name.
You may want to upload your NDF file list to USB before flashing.
There are 3 ways to load this firmware:
1) Put the KURO2.stb file on the root of a USB drive and insert into box, the box should detect the firmware and update automatically
2) If it does not auto-load, press Menu, then from UTILS "Download", enter the PIN (0000), select the file and Press OK to load..
3) Use the RS232 loader with the box connected to a PC with a null-modem cable
Do a factory reset and then scan for channels or load your NDF.
Digital Kaos - Downloads - Eurovox EX6000 Nov 25th Update
