Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    DK Veteran lincsat's Avatar
    Jun 2008
    Default Eurovox EX6000 Nov 25th Update
    EX6000SD Nov 25th release
    Just a couple of cosmetic changes,
    1) "FAV Key" function added - Pressing FAV key while in Fav Channel List moves forward thru categorys, same as RIGHT key press.
    2) "Recording File Name format" changed to Event Name/Date/Channel Name.
    You may want to upload your NDF file list to USB before flashing.
    There are 3 ways to load this firmware:
    1) Put the KURO2.stb file on the root of a USB drive and insert into box, the box should detect the firmware and update automatically
    2) If it does not auto-load, press Menu, then from UTILS "Download", enter the PIN (0000), select the file and Press OK to load..
    3) Use the RS232 loader with the box connected to a PC with a null-modem cable
    Do a factory reset and then scan for channels or load your NDF.
    Digital Kaos - Downloads - Eurovox EX6000 Nov 25th Update
    satsmo's Avatar
    Jun 2008
    Cheers tested earlier and works fine.
    Newbie balmoral10's Avatar
    hi i have just purchased an ex6000 usb2 loaded the kuro file on to a usb pluged it into the box it did not load automaticley so went into the menu selected downloads it asked me to select a file but ther was nothing on the screen yet when i put the usb back into the lap top it was there can someone please help
    Quote Originally Posted by balmoral10 View Post
    Have you checked what format the usb stick is in i.e fat32,ntfs and what format the eurovox will pick up?
    I'm not aware of this box but strike's me that the box isn't picking up your file.
    I am still receiving "scrambled channel" on my eurovox ex6000sd. i have loaded the new firmware but nothing. pls help
    Hi, new to this. It is still worth getting a Eurovox or will it soon not be worth it due to new encryption methods from the cable companies?
    badapple's Avatar
    REQUEST
    Quote Originally Posted by jarrj View Post
    Hi m8, have a read of this and similar posts to decide>http://www.digital-kaos.co.uk/forums...gra-3-a-94883/
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    Thanks for this, just picked a box up recently (hope it works for a little while longer
    Nov 2008
    Smile
    Quote Originally Posted by jelope View Post
    please tell me which one is best for virgin media in ilford area.
    ilyas
    Nov 2008
    Smile new box
    Quote Originally Posted by badapple View Post
    hi
    is there any new box which pick up all channel for virgin media.in ilford area.
    ilyas
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    if you want a box that works with an iconnector read up on it here Kryptview (you will need an internet connection)
    hi, thanx to you all my eurovox6000sd is now working thanx to the information i gained from the forums
    many thanx kevin
  13. #13
    HI PLEASE CAN YOU LET ME KNOW HOW IS EX6000SD WORK PLEASE I BOUGHT A NEW ONE BUT SOFTWARE IS NOT WORKING
  14. #14
    hi could someone please help i have just bought eurovox 6000sd most of the channels shows scrambled channels
  15. #15
    hi
    i have just puchased the eurovox 6000sd, what sort of harddrive do i need to fit to it.. would a laptop hardrive work or would it have to be an external one..many thanx
