Hi. If You want try this file.
GianniNOS (5th September, 2018)
hi, i have tryed, but the issue but the problem remains.
If i have understand, you have modified the base map of injection at low rpm. I have the problem on the crancking at medium ECT ...
do you have a2l and hex for this ecu?
Why you want to repair faulty high pressure pump and nozzels by software??
Slowly but sure i do not understand the car repairs from today
enjoy and have Fun
Tom
dominik.m (13th September, 2018)
Alone you wrote : "someone know if is possible to do a hotstart on this ecu?"
I made this for You . You should ask about something different!
Thanks for information,..... But when you say problem occours since flywheelchange, i see it is again a mechanic problem not software problem, and i have learned one thing in past - you cannot solve mechanical problems by software, you only can get some more time till you definitley need to fix. Hotstart fix was an electrical problem, but could be solved by software without any further damage, in your case i think will not succeed
enjoy and have Fun
Tom
believe me the software runs a lot of hardware that should be replaced. Other people have solved my problem with just calibration ...
