    Oct 2017
    Default Toyota landcruiser 2012 immo problem
    i have 2012 toyota landcruiser.
    A locksmith before me reset the smart box 3 times..BUt didnt had the correct key.
    Now it arrived at my garage.
    Problem is now immo light next to clock is not blinking.
    switch is not getting on.
    i get the key data from smart box by tango.
    but its immobox need to be reset.
    PLease help how to reset the whole system.
    i am able to switch on from fusebox for scan purpose.
    its only showing dtc B2289
    i need to reset ,if anyone know please help.
    Regards,
    Asif
    Nov 2016
    Hello
    Post here your dump
    Enviado desde mi iPhone utilizando Tapatalk
  3. The Following User Says Thank You to UliZam For This Useful Post:
    Asifmehmmod1 (6th September, 2018)
    Oct 2017
    Thanks for reply..
    i have smart ecu dumps only...if you want id box dump and ecu dump i can read them also.also steering is in lock position.
    land2 is original dump.i read it as 16bit.
    2111 is dump i create with tango.
    Regards,
    Asif
    Nov 2016
    Hello
    Need ID Box dump too
  6. The Following 2 Users Say Thank You to UliZam For This Useful Post:
    Asifmehmmod1 (6th September, 2018), dritan (6th September, 2018)
    dritan's Avatar
    Apr 2013
    And ecu dump and part number for every ecu (ecm-smart ecu-id box ecu)
    Quote Originally Posted by UliZam View Post
    Hello
    Sent from my GT-I9301I using Tapatalk
  8. The Following User Says Thank You to dritan For This Useful Post:
  9. #6
    Oct 2017
    thanks all. problem solved...
